Choose language
Examen
Erreur trouvée? Sélectionner la faute d'orthographe avec la souris et presser Ctrl+Entrée.
What's new in SprutCAM 10
SprutCAM 10
SprutCAM v10 Fact Sheet
Download SprutCAM
New Scallop operation added
ScallopToolpath
Scallop (or 3d constant stepover) tool path starts with curves lying on the part surfaces and repeatedly offsets them inwards until the curves collapse.A consistent stepover across the part surfaces is guaranteed The tool path is well suited for high speed machining of complex molds and sculptured models.
Features:
  • Lightning fast toolpath calculation.
  • One entry, one exit. It is possible to machine a whole part with a single continuous spiral-like toolpath with only one entry and one exit points.
  • High speed machining. It is possible to generate a toolpath with rounded corners.
New Face Milling operation added
FaceMilling
Face Milling operation removes stock from the top most level of the part. Three strategies are available.
  • High speed spiral. With this strategy a spiral-like tool path is generated. The tool path is guaranteed to never exceed the given stepover, so you can set the maximum feed rate for machining without worrying the tool will break The sharp corners of the toolpath can be rounded. The Roll-in technique is used to maximize the tool life. Stepovers up to 99% of the tool diameter are allowed.
  • Zigzag. A simple zigzag like tool path is good for removing a thin material from the top of the workpiece. It is designed to be efficient. No air cutting is done. Even the link moves between slices can be done in the material.
  • Parallel (climb and conventional).
High speed cutting extended
hsm_trohoids_zoom84 hsm_links2 hsm_safedistance_zoom89
New trohoidal arcs reduce the tool path length on 20% in compare with version 9. Tool load is much more smooth. Most of the links are rounded. A lot of the links are performed without retraction on the safe level.
Advantages: smooth cutting, longer tool life, shorter tool path.
Available in operations: Roughing waterline, Pocketing, Flat land finishing.
Finishing optimized plane and Finishing complex operations redesigned
image_5_2_1-14
In the previous version these operations consist of two operations with different parameters contained in one group. This gave some discomfort at work. Now, each of these operations is a complete and indivisible operation.
New Knife cutting operations added
Knife5d
Knife cutting operations 2D and 6D are developed to control the tool that must be directed along the motion. It can be knife, band-saw, disk-saw etc. In the common case it requires 6 simultaneously controlled axes.
Features: possibility to use the new kind of a tools, automatic knife orientation and inclination angles calculation for lead in/out and working motions.
New Jet cutting 4D operation added
JetCutting4D
Jet cutting 4d operation can be used for hydro, laser, plasma etc. cutting types where the tool is a jet or a beam. It allows to machine simple elements and also more complex elements with inclined sides. Working contours are set the same way as in the Wire EDM operations, however, the resulting path is generated in the format of "point + normal" or "point + rotary axes of the machine."
New Welding 5D operation added
weldingbox_zoom40
It implements the functional of automatic weld seam geometry calculation without reference to a particular type of welding equipment (i.e., does not generate the specific commands to the laser, electric arc, gas burners, ultrasonic device, etc.). It is enough to add the edge between welded parts to the Job assignment and the system automatically calculates the angles in each curve point so that the welding head is held as close to the middle between the adjacent walls and do not collide with them. Then you can switch to the Simulation mode to see how the material is added to the place where the tip of the welding head is touching.
New Cladding operation added
pocketcladding_zoom30
It implements the concept of additive manufacturing, when, in contrast to a cutting the material is not removed, but added to the workpiece during the machining process. It allows, for example, to build on the surface of the workpiece the layer of material having specific characteristics: high hardness, strength, wear resistance, anti-friction properties, corrosion and heat resistance, etc. It allows also to restore the geometric dimensions of costly parts and tools, to repair blades, dies, molds, gears, shafts, etc. The interface of job zone definition and the set of parameters is similar to the pocketing operation. It allows using curves and edges of the 3D model to restrict the area in which you want to make a buildup of material. Depend on the selected base surface this area can be positioned on the plane, cylinder or on the revolution body. And when the "Project toolpath onto the part" option is enabled, cladding in general can be made on the surface of an arbitrary shape. Operation has Parallel and Offset strategies to fill the area. You also can define total layer count and side angle for the walls.
Robot optimizer feature enhanced
robotmapchanged_zoom20
The UI and the comfort of using of the "Toolpath optimizer" window enhanced. The scales and the slider added for easier tracking of the current position. Now different kind of errors on the map displayed in different colors (unreachable areas, axes out of limits, singularities). Collision detection zones visualization added to the map. Changes in a map may be applied directly to the toolpath without the need of complete operation recalculation.
The list of strategies expanded to control the rotary table. Now, the system allows to calculate the position of the table depending on the tool axis orientation or position of the tool tip relative to the axis of rotation, or with a combination of both previously mentioned laws.
Flexible axis feature added to the Rotary machining operation
rotaryflexibleaxis_zoom40
It can greatly simplify the processing of parts "such as the crankshaft," in which there is a clear axial asymmetry. When this option is enabled, the axis about which the work passes formed begins automatically be considered as the arithmetic mean point in each of the sections. As a result, the trajectory is obtained uniform, without breaks, with the correct tool axis orientation change relative to the part.
New Facing cycle added to the Lathe contouring operation
lathefacecontouring_zoom22
It allows to program facing operation with only one mouse click. Toolpath generated same way as in Profile or Offset cycles just source geometry is changed. It automatically calculates source curve as left or right face of the part with extending it to the current workpiece area.
Feature based machining (FBM) updated
Effortless Machining Knowledge Base growing
Major improvements in the UI and stability
New Hole Groove feature
HoleGroove
The functionality of the Feature based machining extended with Hole grooves machining. In addition to the previously implemented feature types "Simple hole" and "Stepped hole" recognition of "grooves in holes" added (rectangular, trapezoidal, round, shaped, etc.). For grooves became available following machining strategies: boring, rough pocketing, rough and finish contour milling, chamfering. Thus, with FBM become possible to easily and quickly complete programming of machining cycles for holes of any complexity.
Shaped cutters in FBM.
fbmshapetool_zoom40
In FBM the ability to use shaped tools created by the user added. Thus, if the machining of any element type requires a special tool which is not in the system, the user can draw the parameterized tool contour and save it as a new type of tool. All the parameters that the user has placed in a new tool (diameter, height, rounding radius, angles of different tool parts) can be used in the expressions, which the selection of the optimum tool based on.
Visualization, simulation and user interface
Updated 3D visualization
videcard_zoom30
New Advaced rendering mode with the latest OpenGL features. Intel embedded video card bugs resolved. Significantly increased the speed of the  NVIDIA graphics card. New "Rendering mode" combo added to the System setup window. It allows to change rendering mode depend on your video card possibilities. It can help to resolve problems if your graphical adapter does not support some of the visualization features.
Suitable video card selection procedure added to the installation utility in the cases when your PC has more than one video card.
Toolpath visualization enhanced.
toolpathvis_zoom36
Toolpath colorization depend on feed type now is possible (rapid, approach, working, retract etc.). Correspondent move command in simulation tree colorized same way. Current movement now displayed as red bold line with arrow.
New simulation types added
carpainting_zoom35
Additive simulation - adds material to the workpiece at the point where the tool has passed. It is used to simulate the processes of welding and cladding.
Painting simulation - does not add and does not remove material. It just colorize the surface of the part or workpiece following the tool. It is used to simulate painting and heat treatment processes.
Rotary machining job zone parameters visualization
rotaryangles_zoom49
now performed directly in the graphical window. Stand up to the corresponding parameter in the properties inspector to make it visible. To change one of the job zone sizes you can mouse drag corresponding side of the visualized sector or specify the exact numerical value in the text box that appears next to dimension line.
Live toolpath preview
The operations like Waterline and Plane now have special preview of toolpath that appears when you click to one of the parameters inside properties inspector. When you changing parameters, for example, machining step, angle of passes, or job zone angles, it is updating in live time. You can change some of the properties in graphical window directly by dragging corresponding objects.
Advanced collision control.
The collision control of the part with machine components now checked not only the cutting part of the tool but also full tool holder items.
New Axes graph window added
axesgraph_zoom44
It allows to see the changes of machine coordinates depending on the length of the toolpath. This makes it possible to get an idea of the rate of changes, detect frequent direction changes, identify the potentially dangerous places with bounce.
Operation properties displaying enhanced
both for the main parameters window and for the quick properties inspector panel. Now the visibility of exact parameter depend on the current machine possibilities and the selected machining strategy.
More comfortable lathe cycle properties editing
latheprops_zoom44
Lathe cycles' properties of the Lathe contouring operation that was placed in the second level dialog window now moved (duplicated) to the main properties inspector of the operation similar to the all other operation options.
New "Send technical support message" window designed
supportmessage_zoom62
It integrated with the user request management system. Now you even don't need to have installed mail client on your PC. If you have internet connection a message is transmitted immediately to the web service of SprutCAM support. Some files can be attached automatically to the message. It can be the log files of the system, configuration file, the machine schema, the last working project and any other files desired by the user. The more information you give, the more quickly get the answer. То track changes that occur in each new system update, and to check news about resolving your notes you can use the appropriate online service https://www.sprutcam.com/SprutCAMChanges.
New cloud interactive help system designed - Smart hint
smarthintnew_zoom41
If you see an unfamiliar new parameter and have seen a question mark next to it you can click on it. A tooltip will appear. In addition to the textual explanations it can contain pictures, videos and links to training materials. The information is loaded from a cloud help storage, and if it is not available, then from a locally installed distributive. And if you are an advanced user and have the special access rights, then you can login and edit this content. You can explain the meaning of the required parameter in your own language and share that information with SprutCAM users worldwide.
New machine selection window created
f_clip0797_zoom34
It allows to select and add new machines much faster, simpler and reliable. If you do not see desired machine in the list, just put the machine file to one of specified folder, or add the folder where you keep all your machines to the search path list and just click "Refresh" button. Forget about the inability to connect the two machines with the same identifier. Now you can even switch between different versions of one machine in a single click. Moreover, if the machine file was updated, there is no need to restart the entire CAM, just press "By default" button in the machine selection window. By the way, if you open a project and the system will detect that it was created using a different version of the machine, it will show a warning and offer to upgrade it.
3D Model and geometry kernel
Internal STEP format import enhanced
stepfile_zoom22
Native Parasolid format import.
Allows you to import models in Parasolid format in SprutCAM. This function works in the "experimental" mode. Benefits: allows you to import models without installed on the user's PC CAD systems that support this format (eg - SolidWORKS, SolidEdge).
Reimport 3D model feature
reimportfeature_zoom80
Now when you import any 3D model to SprutCAM the name of the source file will remember. Then if this file will change you just will the see special mark next to the corresponding folder in the 3D Model tree of SprutCAM and "Reimport" button will became visible. It is enough to click this button to get newest model inside your SprutCAM project.
Associativity support for the STEP and Parasolid file formats.
Now when you import similar STEP or XT files then all similar 3D model items must have same identifiers. Even after sewing of the model the edges must save their names (they consists of the names of the left and right connected faces). So you can simply use similar 3D models in one project without need to recreate full project again.
Addins for CAD systems
f_clip1170_zoom58
All addins for main CAD systems was updated for using with the last version of corresponding products: SOLIDWORKS 2015, SpaceClaim 2015, Inventor Professional 2015, Rhinoceros 5, etc.
Cutting tool
New cutting tool types for undercut machining
groovetools_zoom63
  • Round groove mill,
  • double-side chamfer mill with sharp and rounded edges,
  • indexable chamfer mill.
Two tooling points using
twotoolings_zoom86
In the hole machining cycles of the FBM the ability to use several tooling points (two tool correctors) in one operation added. It is useful, for example, while boring or milling groove inside holes.
Scripting possibilities
scripts_ide_image_zoom48
Advanced possibilities of script programming language. Allows to adopt existing operations with defining scripting handlers on operation events. Also you can add your own script based operations. API is used to get access to the operation parameters and calculation kernel. It is possible to include external libraries (DLL). Advantages: possibilities of unique special operations creation, or changing of existing operations. Integrated programming environment. Object-oriented access to the operation parameters.
Machine schemas
Shortest path axes rotation
shortestpathrotation_zoom75
New property added to the machine axis description structure 'Support shortest path rotation'. If it is enabled then simulation system will select direction of rapid feed rotations for this axis automatically depend on what path will shortest. For example, movement from 15 degrees position to 350 degrees will rotate axis on -25 degrees instead of +335 degrees.
New machines support added
NewRobots
New machine schemes for robots Denso, Ever, Kawasaki, Manutec, SunLiFia, Mitsubishi, Toshiba, Nachi and many other milling, lathe-milling, wood, etc. machines added. Machine scheme description modified to be possible to use solutions with the controlled 6th degree of freedom (rotation around tool axis). This may be various circular saws, knife cutters, laser temper equipments, etc.
Postprocessing
New toolpath frame output formats added
toolframeoutputtwoangles_zoom50
  • «Two angles AB»,
  • «Two angles BC»,
  • «Two angles BA»,
  • «Two angles AC».
Usually tool orientation described with three spatial angles A, B and C in various order (exactly inside multi-coordinate MULTIGOTO motion). When using  one of the new formats orientation of the tool recalculated such way that tool axis will be unchanged but one of the A, B or C values becomes zero (coordinate system rotates around tool axis). Then tool orientation unambiguously defined with only two spatial angles. It is useful while writing postprocessors for special types of machines such as wood multiaxes machines or machines with inclined rotary axes when physical rotary axes' values don't match to the common spatial orientation angles and manual recalculation between different angle types is difficult.
Download SprutCAM
Система Orphus
Recevoir un appel
